How do I Edit Products on eCommerce website?
June 20, 2013 06:43am by Apptivo FAQ
Posted In: items App | Items
Tagged In: Update Record
Answered on February 24, 2017 02:44am by RAMKUMAR S
The products displayed on your website can be easily edited using the "Product Management" section. Typically each product has a different description and can be edited, but sometimes to make it easy for you a single product might contain all the product pages content. Please contact your account manager to find out if all your product page content is associated with a single product. Please follow these instructions to edit the product description:
  • Log in to your Apptivo account and navigate to "Product Management" section.
  • Under the "Product Management" section, click on "Items App".
  • Search for the product name you would like to edit and click on its name.
  • Once the product page opens up, click on "eCommerce" tab and scroll down to the lower half of the page.
  • In the lower half you will find sections called "Text Content" and "Image Content". These sections contain all the product related information which can be edited by clicking on the "Edit" links.
  • *important* After pressing "Save" in the pop-up, you need to again save the product by clicking on the main "Save" button on the top right side of the screen.
  • Once you have saved your work, publish your changes.
Add Answer
Add your answer...
