How do I Customize My Follow Ups in home dashboard?
Updated on March 30, 2021 06:10AM by Admin
Follow-up is a process of monitoring the existing objects in the future period. Follow up schedule needs to be maintained in order to avoid missing potential objects. Thus, My Follow-ups can also be customized to set as per your needs.
Steps to Follow
  • Log in to your account and click on the User Menu and select Preferences.
Home Page
  • Click on "Collaboration" from the left navigation panel.
  • By default, your account set up would display all views in the left navigation panel.
Hide my follow-ups
  • You can hide the "My Follow-Ups" option from the home dashboard left navigation panel. Just disable on "Hide" button against "My Follow-Ups".
Follow Ups
  • By disabling the Follow-up toggle, the follow-up activity will be disabled from the home page.
Not available
Steps to Customize My Follow-ups Schedule
  • Click on "Follow-ups" for more options.
  • You can view the following options:
  • Calendar View - This setting allows you to view in days, weeks, or months. You can set it as the default calendar view.
  • List View - This setting allows you to view in list format.
  • Table View - This setting allows you to view in the table format.
Views
  • You can also drag and drop the options, which you would like to view as a default one.
Drag and Drop
Why do I receive an error pop-up?
  • You cannot hide all views simultaneously, at least one view should be enabled.
Error Popup
