How do I add requirements to project?
Updated on July 24, 2020 12:59AM by Admin
  • Log in and access Requirements App from your universal navigation menu bar.
  • Click on “Show All” from the left navigation panel.
Requirements App
  • Select the requirements in which the project has to be added.
Select Requirements
  • Click Bulk Actions → Add to Project.
Bulk Action
  • The Projects - Search and Select popup will appear showing all the projects available in your Projects App. Select a project.
Search and Select
  • You will receive a success message once the project is added.
Requirements Added
  • The selected requirements will be listed in the 360-Degree View of the Project chosen.
Projects App
