How do I Convert Estimate into a Work Order?
Updated on July 14, 2020 07:26AM by Admin
The conversion of an estimate into a work order is the beginning of the manufacturing process. And it will be more likely linked to a bill of material and other resources used. Therefore, the work order will probably show the following.
  • The item being serviced or the quantity of the item/product to be constructed or fabricated.
  • The problem summary and the service delivery window.
Steps to Enable
  • Login and access the Estimates app from the universal menu.
  • Click on the More(...) icon and select the Settings.
Estimates
  • In the Settings page, click on the Estimates and select the Conversion.
  • From the Conversion page, you can view the Standard and Custom conversion.
  • Enable the Toggle for Allow conversion from estimates to Work Orders.
Conversion
  • By selecting the Custom conversion, you can view and map the attributes of the Estimates with the Work Orders attributes.
  • Click on the Mapping button.
Custom Conversion
  • In the Mapping page, you can also associate the objects like Tasks, Events, Emails, Notes, and Call Logs.
Mapping
  • You can map the Work Orders attribute with the Estimates Attributes by selecting the attributes in the Select Attribute dropdown.
  • Once the mapping is done, click on the Update button.
Save
Steps to Convert Estimate into Work Orders
  • Create a new estimate or select an existing estimate to be converted.
  • Click on the Convert button and choose the To Work Orders option.
Convert
  • You will be directly redirected to the Create Work Orders from the Estimate page with the auto-populated mapped attributes from the estimates app.
Create Work order
  • Then, click on the Create button at the bottom of the page.
Create button
  • The Work Orders will get created.
WO Created
