Projects App from Apptivo helps you to manage all the project’s goals and the objectives. It will allow you to create subprojects inside the main projects. Creating the Subprojects helps you to divide the work of the main Projects and assign them to the different teams. So that the project might fall into the set of sub-projects and each can be performed by the subset of the overall team.
Let's consider Miss.Sarah Castro is the Project Manager and she wants to create a subproject for a master project so that she can assign the subproject to the various set of teams and it will help her complete the whole project on time. Please follow the steps to create the subproject for a master project.
Steps to Create
- Login and access the Projects App from the Universal Menu.
- Select the Project from the list and click on the More Options.
- In the Project Overview page, scroll down to view the Sub Project section.
- Click on the Create Sub Project and select the Create New Project.
- By selecting the Create New Project, you can view the create project side panel.
- In the Create Projects panel, add the name of the Project.
- Select and add the start date and end date of the project.
- Select and search the Customers from the list.
- After adding the mandatory fields, click on the Create button.
- Your Sub Project will get Created.
- Once the Sub Project is created, you can view the created project under the Sub Projects list.
How do I enable the Subprojects?
