How do I Delete a Project?
Updated on September 29, 2020 06:33AM by Admin
Projects App helps to create and maintain projects provided by the clients. You can assign employees to keep track of all the projects. If a project has accomplished its purpose then it can also be deleted.
Steps to Delete a Project
- Log in and access Projects App from your universal navigation menu bar.
- Click “By queue” and select “My Projects” from the left navigation panel.
- Choose a project from the list, and click the "More Details(...)".
- The project's overview page can be seen. Click on the "Delete" button.
- You can view a "Warning popup".
- Click "Yes" to delete.
- If the project is associated with any other apps or projects, then it cannot be deleted. It will be moved to trash.
Note: If the Projects are converted to "Timesheet" or "Invoice", those cannot be deleted.
