How do I Configure Create Flow for Creating Timesheet from Single Project?
Updated on November 23, 2016 10:38PM by Admin
In Timesheets Creation Flow, we can customize the methods to create timesheets. Here, you can enable/disable the methods used for timesheets creation.
Steps to Customize Creation Flow
  1. Log in and access Timesheets App from your universal navigation menu bar.
  2. Click on "More(...)" icon and select "Settings" located at the app header bar.
    timesheet settings
  3. Click on “Create flow” under "Timesheets" drop down from the left navigation panel.
    select create flow
  4. The Create Flow page will be displayed as shown:
    create flow page
  5. Toggle ON “Create timesheet from project”.
  6. Choose “Single Project” option to create a timesheet with single project.
  7. The changes will be auto-saved.
