How to setup Invoices Tax code for Moscow, Russian Federation?
Updated on October 19, 2016 06:12AM by Admin
Users in Moscow, Russian Federation can easily set up their online Invoices to charge for the sales/services taxes.  In Moscow businesses are required to charge VAT taxes on all products/services they sell. You can use our single rate tax code calculator to make these tax rates available for use when creating invoices.
The tax code followed in Moscow, Russian Federation
The Value Added Tax (VAT), is a form of consumption tax and it is collected at the standard rate of 18% on all supplies of goods and services. While a lower rate of 10% is applied to certain goods like Children clothing and Footwears.
Reference: Value Added Tax (VAT) rates of Moscow, Russian Federation is referred from Wikipedia and Tax rates web sites.
Steps to Configure Taxes on Invoices App Settings
  1. Log in and access Invoices App from your universal navigation menu bar.
  2. Click on “More” icon and select "Settings" located in the app header bar.
    invoice settings
  3. Click on “Invoice” and select "Taxes" from left navigation panel.
    taxes
  4. Select “Single Rate Taxes” on taxation.
    create single rate tax
  5. Click on “Create” button to create a single rate tax.
  6. Provide the following:
    • Tax Code – Code of the tax.
    • Tax Rate Type – Select a type either fixed or percentage.
    • Tax Rate – Rate of the tax (percentage or amount).
    • Print Label – Name of the tax.
  7. Click on “Create” button to complete.
  8. You can view the created single rate tax code in a list.
    overview Taxes
  9. By default, the created single rate tax will be in enabled mode.
  10. You can proceed creating a new invoice with the above settings.
  11. You can either E-mail an invoice with PDF attachment or manually print invoice to the customer.
  12. You can view the invoice Tax code items subtotals on PDF format.
    pdf template
  13. You can capture the tax code at invoice header level and line level.
