While creating a Timesheet, how does my Employee Pick a Project associated with a Customer?
Updated on August 10, 2020 05:02AM by Admin
Most businesses require some sort of reporting on the time spent on various activities, whether this information is reported to a manager within your company, or to the customer. The Timesheets app supports the creation of timesheets in addition to a process for managers/customers to either approve or reject the timesheet.
Steps to Create Timesheet from Projects
- Log in and access the Timesheets App from your universal navigation menu bar.
- Configure settings to create a timesheet with a single project.
- Click on the “Create” button, select “From Project” from the left navigation panel.
- Fill in the following information:
- Customer – Search and select your existing customer.
- Start date – Start date of the timesheet.
- Period – Duration of the timesheet.
- Approver – Name of the approver of the timesheet. Here “Project Manager” will be pre-populated.
- Project – You can view a list of projects associated with the selected customer.
- Task – You can view a list of tasks associated with the selected project.
- On clicking the search icon in the Projects field, you can search and add a project from the Timesheets App.
- Click on “Create” to save the timesheet as a draft.
- Click on “Create & Submit” to submit this timesheet for approval.
- Hence, the timesheet shown above is created from a single project. It will be submitted to the project manager for approval. In this example, “Caroline Forbes” is the project manager to approves the timesheet.
