How do I Print Work Order Information?
Updated on February 28, 2019 01:28AM by Admin
Work orders App allows you to print your work order information using the "Print PDF" option in the overview page. The followings steps will give a clearer picture.
Steps to Print Work Orders
- Log in and access the Work Orders App from your universal navigation menu bar.
- Click on “By Queue” and select “My Work Orders” from the left navigation panel.
- You can view all your work orders. Click on "More Details(...)" icon.
- In the work order overview page, click on “Print PDF” button.
- Select “Open” work order PDF and click on the “Ok” button.
- Now, you can view your work order PDF information.
Note: You can also enable Serial Number in the Work Orders both in the Overview and the Print PDF pages.
Steps to include Serial Number in Work Orders:
- Navigate to Settings in Work Orders from the "More Options(...)"
- Click on the Master Layout from the Customize App dropdown.
- Select the “Products/Items Sold” section, in the Inspector Tab, you can find the Auto-Generate toggle disabled under the Numbering section.
- Enable the Auto-Generate toggle, in the Inspector Tab.
- You can view the Serial Numbers for the Items in the Overview Page of the Work Order.
- Now, Click on the Print/Web Layout from the Customize App dropdown.
- Select the “Products/Item List Sold” section, you can find the Auto Generate toggle disabled in the Inspector Tab.
- Enable the Auto-Generate toggle. In the Inspector Tab.
- You can get the Serial Numbers in the Print PDF layout.
