How do I customize kit order number generation?
Updated on April 3, 2017 11:30PM by Admin
For every kit order placed, a unique number will be generated for reference purpose. This unique numbers for the kit order can be generated in the following two ways:
  • Manually Entered
  • Automatically Generated
For instance: Consider there are a numerous number of kit orders created. An employee who wants to search for a particular kit order, can now instantly search for the kit order using this unique number.
Steps to Customize Kit Orders Number Generation
  1. Go to Kit Orders App.
  2. Click on "More (...)" -> "Settings" -> "Kit Orders" -> "Number Generation".
  3. In the "Numbering" page, slide the toggle OFF, to manually generate kit order numbering.
    generate numbers manually
  4. To automatically generate numbers, slide the toggle ON for "Auto Generate" and specify the:
    • Prefix - Enter the prefix to be added to the kit order number.
      • You can choose either "Static Text" or "Year of Kit Order Date".
    • Starts with - Starting number of the kit orders.
      enter prefix and start date
  5. For instance: If you choose the "Year of Kit Order Date", the kit order numbering will start with the current year.
  6. The changes made will be saved automatically.
    year of kit order date
  7. On creating, the kit order will have the numbering as follows:
    kit order numbering
