How do I Create Invoice Tax with Print Label?
Updated on April 5, 2018 04:48AM by Admin
Invoices app allows you to create print label. Print labels displays the name or type of the tax. For instance: If you are creating taxes for United states then you provide the print label as VALUE ADDED.
Steps to Create Invoice Tax with Print Label
  1. Log in and access Invoices App from your universal navigation menu bar.
  2. Click on "More" and select "Settings" icon located at the app header bar.
    setting
  3. Click on "Taxes" from "Invoice" drop down from left navigation panel.
    taxes
  4. Click on "Create" button.
  5. You can view "Create Single Tax" popup, as shown below in which you can find:
    • Print Label – Provide label for tax, which will be shown while printing invoices to customer
      create pop up
  6. Click on “Create” button to complete.
  7. You can view the created tax with a label in invoice PDF.
