How do I customize my home page from Business settings?
Updated on May 21, 2020 06:54AM by Admin
When accessing your account you can view the Home page dashboard that organizes all of your activities. You can also customize the homepage settings as per your desire.
  • Connect into your account and click on the User Menu at the top right corner. Select Business Settings from the dropdown menu.
User Menu
  • Click on Customize Home from the left navigation panel.
Customize Home
  • In the Customize Home Page, you can manage the header menu and header color.
Customize Page
  • By enabling the Enforce these settings for all users toggle, the changes made here will be reflected on your employee’s home dashboard.
Toggle Enabled
  • In the Menu Bar setting, you can choose how to view and navigate between your business apps.
  • Click on the radio button and select the required view of the Apps. Apptivo offers two kinds of views:
    • Grid View
    • List View
  • To view the App Header in Grid View, select the Grid View’s radio button.
Grid View
  • The App Header will be displayed in the Grid View.
Grid View Updated
  • To view in the List View, select the List View’s radio button in the Customize Home Page.
List View
  • The App Header will be displayed in the List View.
List View Layout
  • In the Header color setting, you can choose the background color and text color of the header bar.
Header Color
  • The performed actions will be auto-updated and you can view the changes in the home dashboard.
