How can I Give Permission to Users to Create an Employee?
Updated on November 19, 2016 12:41AM by Admin
Employees App permits to provide access to the users who are supposed to create Employee in Employees app. The users who have privilege for creation feature can access the “Create” button found in left navigation panel of Employees App.
For instance: If a super user (Katie Dustin) wants to give privilege for access Creation feature to his employee (James William), then he will do the succeeding steps.
Steps to Give Permission to Users to Create an Employee
  1. Log in and access Employees App from your universal navigation menu bar.
    image result for give permission to create a employee
  2. Click on “More”  image result for employees icon and select “Settingsimage result for employees located at the app header bar.
  3. Click on “Actions” from security drop down found at the left navigation panel.
  4. Locate the “Create” option and click on privileges drop down.
  5. Click  on "Create privilege" option found at the bottom of the privilege drop down.
  6. Create privilege pop up appears. Enter the name and description of the new privilege that you want to add against the "Create" option.
  7. Click on "Create" button.
  8. After creating the privilege go to “Employees App” to create a new role.
  10. Now, employee James William has the privilege to create Employee in Employees app. In James William login, the “Create” button will be visible as shown in the image below:
