How do I customize the List Layouts in the Items App?
Updated on August 29, 2022 04:35AM by Admin
List Layout of Apptivo allows you to customize the layout of the records which helps to arrange the information of the records as per your business preferences. It guarantees the exact data by removing redundant information. The Items app of Apptivo allows you to manage all of your items without any hassle. You can have all the information about your items using one app.
Steps to customize the List Layouts:
  • Log in and access the Items App from the universal navigation bar.
  • Click on the More(...) icon and select Settings.
Items - Settings
  • On the Settings page, Go to Customize App → List Layouts. You can see the list layouts available for the Items App in the right panel.
  • You can create a new Layout by clicking on the Create button.
Items - LL Create
  • Select a list for customization. Here, I have chosen the created layout.
  • Click on the Default name to change the Name of the layout. Here, I have renamed it "Items Info". It will save automatically on clicking outside the Edit area of the name.
Items - LL Eidt Name
  • Now, select Display from the right corner of the list.
  • You can see the set of attributes present in the Items details list is selected by default in the Display section. To remove a particular attribute, you can untick the particular attribute from the Display section.
Ittems - LL tick Untick
  • You can also select the new attributes from Display to add them to the list.
  • Here, I have added the Item standard cost and also modified the sequence of the layout as shown below.
Items - LL Ticked
  • Navigate to the Show All page in the Items App. Click Display’s layout dropdown and select “Items Info”.
Items - LL Show All
  • You can see the updated list for all the records based on your customization.
Items - LL Final SS
