How can I Give Access to Users for Side Panel View in Timesheets App?
Updated on November 30, 2016 05:13AM by Admin
Timesheets App allows you to provide access to the users who are reputed to access “Side panel” view in Timesheets App. The users who have privilege for this access, can use the “Side panel” feature found in overviewl page of Timesheets app.
Steps to Give Permission to Users for Access Side panel to View Created Timesheets
  1. Log in and access Timesheets App from your universal navigation menu bar.
    timesheets
  2. Click on “Moreimage result for more icon icon and select “Settingsimage result for more icon located at the app header bar.
    image result to access settingss for using delete feature
  3. Click on “Actions” from Security drop down from left navigation panel.
  4. Locate the “Side Panel” option from “Apps” section and click on privileges drop down.
    image result for access security actions to view side panel
  6. Create privilege pop up appears. Enter the name and description of the new privilege that you want to add against the "Side panel" option.
  7. Click on "Create" button.
    image result to create privilege for view sidepanel
  8. After creating the privilege go to Employees App to give access to particular employees.
  9. Please refer think link: https://answers.apptivo.com/questions/12694/how-do-i-assign-custom-privilege-to-employee-for-managing-objects-found
  10. Now, employee James Williams has the privilege to access “Side panel” option in Timesheets App. In James Williams login, the “Side panel” view will be visible as shown in the image below:
    image result for view side panel
