How to view candidates with preferred column sets?
Updated on September 1, 2021 10:17PM by Admin
The Candidates app allows you to add or remove specific fields as per your requirements using the list layout feature. By customizing the list layout in the Candidates app, you can view the fields of your preferred choice in table format. Just tick or untick the checkbox to add or remove fields.
Steps to configure
  • Log in and access the Candidates app from the universal navigation bar.
  • Select Settings from the App Header.
Candidates page
  • From the Settings page, click on the Customize App → List Layouts from the left navigation panel.
List layout
  • Select Create button to create a new layout. A Default layout is added.
  • To change the name of the layout, hover your mouse pointer over the name. A pencil icon will come into view. Here, change the name of the layout.
Changing list layout name
  • To add or remove fields in the layout, select the Please Choose dropdown button next to Display. It will display the fields present in the Candidates app.
  • To add a field, tick a field from the dropdown. To remove a field, you can untick a field.
  • Here Candidate #, Status, First Name, Last Name, and Date of Birth are added from the Candidate Information.
select fields
  • After customization, go to the Candidates app dashboard.
  • Click on the Display dropdown to select the desired layout.
Preferred layout
  • Now, the customized attributes will be displayed based on the selected layout.
Result
