How to create Work Order from Another Work Order?
Updated on February 28, 2020 04:31AM by Admin
Apptivo's Work Order App allows you to manage both product and service process. It helps you to track the time and the products used to resolve the customer-related problems. In addition, it allows creating an invoice inside the application. Accordingly, it helps you to create the work order from another work orders. Please follow the steps.
Steps to Follow
  • Login and access the Work Order App from the Navigation Menu.
  • Click on the Create WorkOrders Dropdown.
Login
  • Select From Another work orders.
Work Orders
  • Here, you can view the list of work orders that are created in the past.
Another work order
Note: With the Action Copy Task and Item toggle, you can enable and disable the copy of the tasks and the Item from existing Work order to the creating work order.
List
  • Then, select the one work Order from the List.
Actions
  • Here, that work order page will open with the copied item and the task. You can change the attribute values as per your business need.
Select
  • Then, click on the Create button in the bottom left corner.
Create Page
  • Work Order will get created.
Created work order
