How to view more than 25 tags from the left panel in Apptivo?
Updated on March 12, 2020 10:20PM by Admin
Tags are great resources that are used to group records, in a particular sequence. Tags can be used for easy retrieval and access of information. Apptivo allows you to list out more than 25 tags at a time from the left panel. In case if you have 200 tags associated with the Customers App. You can view all your Tags at a time by simply clicking on the View more option.
  • Login and access More→ CRM → Customers app from the Universal navigation menu bar.
customersapp
  • If you want to view all the tags, then click on the By tags option from the left panel.
BY tags
  • To view all the Tags in a single page, slowly scroll down and click on the View more option.
viewmore
  • The By Tags: All page will open, In that, you can see all the recorded tags are present on a single page in alphabetical order.
Bytagspage
  • You can also use the Search tab to search for tags.
searchtab
