How to remove a Sub Project from the main Project?
Updated on May 9, 2020 06:01AM by Admin
Projects are considered as a key component for the proper growth of an organization. With Projects, you can easily manage and achieve the goals and objectives of your business. For the main project, you can create multiple Sub Projects and track the tasks associated with it easily. When needed, you can also delete the sub-projects without affecting the main project.
Steps to remove the Sub Project
- Go to the Projects App in Apptivo. Select the Project whose sub-project is to be deleted.
- Scroll down to the Sub Projects section in the Overview Page. You can see the list of sub-projects. Select the Remove icon in the Project that is to be removed.
- You will receive a confirmation popup.
- Once confirmed, the sub-project is removed from the main project in the Projects App.
- Removing a sub-project does not delete it from the Projects App. The project exists in the Projects App. The association with the main project is alone removed.
