How do I create a Miscellaneous Issue?
Updated on June 1, 2020 08:00AM by Admin
  • Consider the Inventory of an item, Electric Motors is as given below.
Item Quantity
  • In your Apptivo account, click Supply Chain → Miscellaneous Issue from the Global Header. You will be redirected to the Miscellaneous Issue App. Select Create to create a new Miscellaneous Issue.
Miscellaneous Issue
  • In the Create Miscellaneous Issue page, document the transaction date, memo, and the warehouse from which the item has to be transferred.
Create Page
  • Scroll down to the Items table. Here, search and add the item to be stocked along with the Receiving Quantity, Locator, Zone, and Device ID.
  • You can also delete or add a note to the item added.
  • To add more than one item, select the (+) icon to add another row.
Item Quantity
Note: You can add only those items created in the Items App.
  • Select Create. A new Miscellaneous Issue is created.
Issue Created
  • After an issue is created, the quantity added in the issue gets subtracted from the Item’s Inventory.
  • Go to the particular Item’s overview page in the Items App.
Items App
  • Select the 360-degree tab → Inventory Management.
  • You can see the On Hand Quantity and Available Quantity is decreased.
Updated Quantity
