How to display a radio button as a toggle for Apptivo’s android application?
Updated on July 13, 2020 08:22AM by Admin
Consider displaying the radio button as a toggle in the Contacts App of Apptivo.
Steps to add the Radio button
  • Login and access the Contacts app from the universal menu.
  • Click on the More(...) icon and select the Settings.
Contacts
  • In the Settings page, click on the Customize app and select the Master Layout.
  • From the Master Layout, drag and drop the Radio attribute from the Palette on the Contact Information section.
  • Click on the Radio button, you will be redirected to the Inspector Tab.
  • Change the Name of the Radio button.
  • Click on the Display as dropdown and select as Toggle.
Radio button
  • Scroll down in the inspector tab to add the value for the Radio button.
  • Enter the Value name and click on the + icon to add.
  • Here the Value is Added as Opted in, Not opted in or out, and Opted out.
Values
  • Once the value is added, click on the Save button.
Save
  • Now, go to the Contacts Create Page from your android device.
  • You can view the added Subscription Radio button display as the Toggle.
Mobile View
