How to create a highlighting for completed follow-ups?
Updated on October 6, 2021 04:25AM by Admin
Follow-ups in Apptivo helps to manage all your follow-up events in a single place. It also allows you to create a highlighting based on the follow-up statuses. For example, if you want to set different colors for the follows that are in completed status, you can configure the individual color for the follow-ups based on their status.
Steps to Enable Status Field
  • Login and access the Follow-ups from the homepage of Apptivo.
  • From the Follow-ups, click on the More(…) icon and select Settings.
My Follow ups
  • From the Settings page, click on the Master Layout under the Customize App dropdown.
  • On the Master Layout, click on the Hierarchical View and enable the Status field.
  • Click on the Save button to update the changes.
Master Layout
Steps to create Highlighting
  • On the Settings page, click on the Highlighting under the general drop down.
  • Click on the Create button.
Highlighting
  • You will be redirected to the Create Highlighting page.
  • Enter the Name and the Priority Score.
  • Priority Score will help to prioritize the follow-ups based on this highlighting at the time of using multiple highlights.
  • Select the Color for the Background and the Text color from the color picker tool.
  • Add some Descriptions for your references.
Name
  • In the Criteria, set the condition for the color-coding.
  • By using the Insert attributes, insert the attributes of the Follow-up app to set the condition.
  • Here, the condition is set to view the completed follow-ups in the Green color by selecting the status as completed.
  • Then click on the Create button.
  • You can view the list of Highlights once it is created.
Criteria
  • Now, go to the Follow-ups homepage. Click on the Calendar view.
  • You can view the completed Follow-up background and the text color also changed as per the highlighted color on the list.
Calendar View
