How do I Allow Users to Select their Preferred Candidates columns (fields)?
Updated on January 23, 2017 09:08PM by Admin
Candidates App allows you to provide access to the users who are reputed to view display drop down in Candidates App. The users who have a privilege for display drop down are able to access "display drop down" button in Candidates App.
For instance: If a super user (Katie Dustin) wants to give the privilege to access display drop down option to his employee (James William), then he will do the following steps.
Steps To Give User Permission to Select their Preferred Candidate Columns
  1. Log in and access Candidates app from your universal navigation menu bar.
    candidates
  2. Click on “Settingsimage result for employees from “More” icon  image result for employees located at the app header bar
  3. Click on “Actions” from security drop down from the left navigation panel.
  4. Locate the “Display Drop down” option and click on privileges drop down.
    actions-display-dropdown
  6. Create privilege pop up appears. Enter the name and description of the new privilege that you want to add for the “Display Drop down” option.
  7. Click on "Create" button.
  8. After creating the privilege go to Employees App to give access to particular employees.
  10. Now, employee James William has the privilege to select preferred columns on Employee column fields. In James William login, the “Display Drop down” option will be visible as shown in the image below:
    display-dropdown-enable
