How do I permanently delete a project?
Updated on July 2, 2017 11:36PM by Admin
You can view all initially deleted projects in the “Trash” dashboard. From trash dashboard you can permanently delete projects.
Steps to delete a project permanently
- Log in and access Projects app from your universal navigation menu bar.
- Click on “More” icon and select “Trash” icon located at the app header bar.
- In trash dashboard, you can view "Deleted" and "Archived" tabs.
- In "Deleted" tab, select projects to be deleted by enabling check box.
- Click on “Delete Forever” button.
- You can view "Warning popup" page, as shown in the image below:
- Click on “Yes” button to complete.
Related links
Read also:
