How can I Give Access to Users for Side Panel View in Candidates?
Updated on January 19, 2017 01:26AM by Admin
Candidates App allows you to provide access to the users who are reputed to view side panel in Candidates App. The users who have a privilege for side panel are able to view "Side Panel" in Candidates App.
For instance: If a super user (Katie Dustin) wants to give privilege to his Employee (James William) to view side panel, then he will do the following steps.
Steps to Give Permission to Users for Access Side Panel
- Log in and access Candidates App from your universal navigation menu bar.
- Click on “More” icon and select Settings located at the app header bar.
- Click on “Actions” from security drop down from the left navigation panel.
- Locate the “Side Panel” option and click on privileges drop down.
- Click "Create privilege" option found at the bottom of the privilege drop down.
- Create privilege pop up appears. Enter the name and description of the new privilege that you want to add for the "Side panel" option.
- Click on "Create" button.
- After creating the privilege go to Employees App to give access to particular employees.
- Please refer think link: https://www.apptivo.com/answers/questions/12694/how-do-i-assign-custom-privilege-to-employee-for-managing-objects-found
- Now, employee James Williams has the privilege to access “Side panel” option in Candidates App. In James Williams login, the “Side panel” view will be visible as shown in the image below:
